I have a new Nokia 3230 and want to save a copy of my contacts to MMC.I have tried copying the contacts file to mmc but it says that the file is in use and can't be copied.Can anybody help me to solve this problem.
Thanks in advance
Sanjeev
Thanks in advance
Sanjeev
Contacts stay in phone memory and can't be moved.
You can back them up to a memory card by using the built-in "Memory" app and its backup feature.
You can also back them up to a PC using PC Suite (or use it to synchronize them with Outlook or Notes/Organizer on the PC).
You could also search the shop for apps like "Contacts Manager", "Contact Transfer", or "Backup Contacts": http://www.allaboutsymbian.com/shop/
You can also search the list of apps here: http://my-symbian.com/7650/applications/index.php
