Just a quick question for V3.12 user upgraded to V3.16.
6 replies · 2,596 views · Started 07 November 2002
Hi, I was just wondering when u upgrade from version 3.12 to 3.16, does it use some memory from the C drive or is it the full 15MB on the Z Drive?
And what�s the difference between the versions because I�m thinking of upgrading it soon.
I think it takes about 160kb out of C: drive, I did it but you can hardly tell the difference.
One REALLY good thing about getting the upgrade is that 3.12 has a bug when your memory fills up, it doesn't leave enough for your phone to run and you have to do a hard reset and you loose all of your data (It happened to a friend of mine)
Reason enough for getting an upgrade I think.
Make sure you backup all of your numbers and pictures or anything else you want to save as it will be erased when you get the firmware upgrade.
Thanks J2theIZZO, 😊 guess I will upgrade my phone soon.
But it takes up to 2 weeks for u to get the phone back. :x
[quote="J2theIZZO"]Make sure you backup all of your numbers and pictures or anything else you want to save as it will be erased when you get the firmware upgrade.[/quote]
Hey, can I keep all my data (contacts, images, apps, messages, ringtones, settings, etc) using only the Backup of PCSuite??
Thanks! 😉
