It is possible to see Arabic characters in 7710 not only in messaging area(reading arabic sms), but every where else (e.g. in filemanger arabic file names) the only thing you need is an arabic enabled theme with it's associated arabic-fonts
Arabic characters all over the 7710
Thanx a Lot 😊
if you please show me the steps so i can make my 7710 read the arabic. in other way how i can install the arabic font in the mobile ??? thanx
Is there a nokia 7710 arabic theme out there thati can install or get.can you help me man in this.THanx a lot for the information
aaowilliam wrote:Is there a nokia 7710 arabic theme out there thati can install or get.can you help me man in this.THanx a lot for the information
First unzip and copy all of the fonts to C:\system\fonts\ (create the "fonts" folder) using powerfile or nokia pc suite 6.5(or before)
then after a restart install arabic enabled theme
Good work man, it works just great, till i can get to update to firmware 4.01 and check if it has arabic support or not
yeah man grat job put the character in the tilte of the message is backword is there any soultion
mht220 wrote:First unzip and copy all of the fonts to C:\system\fonts\ (create the "fonts" folder) using powerfile or nokia pc suite 6.5(or before)
i have done all the steps as u said ,, but still it didn't work, can u plz help me?
and does anyone knows if there is any arabic support or if there will be arabic support for the 7710 from symbian or anyone else for that matter?
dear mht220
I had some defeculty in doing this
ok
was that in the Pc or the Phone & if it was the Phone How can I do it ?
I did not find the system file
pleas can you explane in detailes
thanks
SAN ANTONIO wrote:dear mht220I had some defeculty in doing this
ok
thanks
copy in phone memory, and to access system folder use powerfile or nokia pc suite 6.5 or before( search the forum for pc suite use) then restart ur 7710 then install the attached theme and enable it afterward
or just buy smsarabic software
