I messed up my 6630 contact list then I decided to delete all of it. Then I tried to sync it back to my Outlook on my pc using the pc suite. the sync was running but nothing updated.
I hard reset the phone and even reinstall nokia pc suite and delete all the nokia folder. Still could not update the contact list.
Is there anyway to force update the contact list? (I could do it with SE K700i)
Thanks,
Iwan
In Nokia PC Sync main screen, hit "Settings" and then hit "Create new settings". After new sync settings have been created, resync. (You can also for this one time make the sync direction one-way; only sync from PC to phone).
N/A wrote:In Nokia PC Sync main screen, hit "Settings" and then hit "Create new settings". After new sync settings have been created, resync. (You can also for this one time make the sync direction one-way; only sync from PC to phone).
I use the pc suite 6.6 I tried your method, but still it won't update the handphone (I know this method work on Windows Mobile)
thanks anyway.
Iwan
