Screen Saver Time Change
5 replies · 2,907 views · Started 13 July 2005
Is there any way to change the maximum time for the screen saver?
I have seen programs that keep the screen backlight on all the time by using the 'KeepBacklightActive' command in the program,
But all I want to do is change the on time to 30 minutes?
Must be an inf file hack?
Carl,
I know it's in the Control Panel, but need it to be longer,
I know on my 9210 there was a program that changed it, So I'm assuming that it's in the registry or INF file?
Carl,
WST wrote:Unless I understood wrong, you can do it with Roman Keller's LightPlus utility. Try the follwing URLs. Finding it was tricky as Roman abandoned developing for Symbian 😞
http://my-symbian.com/9210/download/search.php?name=LightPlus
http://www.romankeller.ch/phpwcms/index.php?id=63,0,0,1,0,0
You'll need the OPL Lib:
http://www.romankeller.ch/phpwcms/index.php?id=76,0,0,1,0,0
Roman's archive is in German.
I hope it works. Good luck...
I've Tried it before,
Ok, it keeps the light on but it's not a well written program, and with no future support, :frown:
I could write something in SBasic or maybe OPL, but would prefer just to change the settings,
Carl
Well, if you're a PowerDesk user, you can assign a 'hotkey' to keep the backlight always on. I find this function very useful and use it all the time when I'm browsing or reading an e-book.
