Stucked message in Outbox Folder
4 replies · 2,989 views · Started 08 November 2002
Hi!!!
Last few days i experienced a little problem with my 7650:
When cleaning the the "Outbox" folder to free up some space, i could not delete one message!
I dont have the "/options/delete" option for this message!
In this folder, the message appear without subject... but it can be viewed in the "/option/Message Detais" option!
I have no Ideia of how to delete this message!!!! Has anyone experience this problem?
Thanks for any help!
this happened several times to a lot of members here, lucky me it has not happend to me yet. there have also been some suggestions on how you can delete it, but silly me, i just cant remember any one of them! LOL. anyway, i suggest you use the search option of this forum and you will find something that will help you, there are available solutions im sure, so sont worry.
hope i made some sense somehow...
look here:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=3276
or better yet, use the usefull User posted image Search function of this board :P thanks. (normally found on upper right side of screen 😉 )
[quote="JyriK"]look here:
or better yet, use the usefull User posted image Search function of this board :P thanks. (normally found on upper right side of screen 😉 )[/quote]
aha!!! there you go! thanks jyrik! hope this helps you napalm.
