Tom Tom Mobile 5 Problem with 6680
2 replies · 3,418 views · Started 14 July 2005
Hi Guys,
I've just got a copy of TOM TOM 5 and I'm trying to transfer the 9 folders to my MMC RS acard through Nokia Suite file transfer.
When it comes to the System folder it nearly completes and then an error comes up to say the the item is not found on phone??
Any ideas?
If I try to create a new folder called system on the MMC card it says "the phone has rejected this request"...
Am I doing something wrong?
:frown:
richieno9 wrote:Got this sorted by using a card reader.
yes you have realised Nokia dont like you messing with the system folder so you can see it or access it using PC Suite. Best option is a card reader and faster for large files.
