How can install appz java ???
1 replies · 2,128 views · Started 14 July 2005
Hi, I�m mexican sorry my english not is good. ja
Who can help me? i�dont know how install appz java(games) in my sendo X using USB with the program Sendo PC connect 😮
Brayanh wrote:Hi, I�m mexican sorry my english not is good. ja
From the FAQ:
Q: How do I install new programs from my PC onto my Sendo X?
A: There are a few methods to choose from, depending on the file type (JAR or SIS)
Send the SIS or JAR file to the handset using BlueTooth or IrDA. It will appear as a new message on the handset. Go to read the message. The system will realise it is a new program and go to install it. Various messages will appear, including to install the program to main memory or memory card. Answer as needed. Program is now installed.
SIS files can be installed using the Sendo PC Connect program which has an Install routine. Browse to the SIS file. Select Install. Various messages will appear, including to install the program to main memory or memory card. Answer as needed. Program is now installed.
JAR files cannot be directly installed using the Sendo PC Connect program. However, using the file browser it can be done. Transfer the JAR file to the C:Nokia/Installs folder. On the handset, load the JAVA control program (in Tools). It will say there are uninstalled programs. Press RIGHT to see the DOWNLOADED tab. The new file is here. Select it to install it. Press RIGHT to go back to the list after it is installed to do any others you transferred.
NB: This method can also be used for SIS files. Transfer them to the same folder as above. On the handset this time however, go into the Program Manager option (also in Tools). The new programs are at the bottom of the list. Installed programs have a cube symbol next to them, on the right. The not installed programs do not. Select the file, and choose Install. Various messages will appear, including to install the program to main memory or memory card. Answer as needed. Program is now installed.
