3 major problems please help
3 replies · 2,562 views · Started 15 July 2005
hi here are my problems
1. my 6260 show a faded out nokia logo on boot and i have to restart the phone befor it comes out normal
2. my charging light blinks instead of staying there
3. the phone keeps asking me about removing my memory card
the last 2 i can bare with but that faded out screen im really worried about plz help
Hi, i think i'm having the same problem before..as it faded and off while I made call. it shocked me. I restarted the phone 4-5 times, no luck as it faded after the PIN entered. But at last, I reseat the MMC on my phone and restarted, solved~! until today. What I suspected was, some application that I installed into MMC failed to load, similar to our Windows couldnt load the startup items... : ) So, you may try to reseat the MMC or without the MMC and see how it goes...
I have no idea about the other 2 questions...sorry mate~!
noname80 wrote:Hi, i think i'm having the same problem before..as it faded and off while I made call. it shocked me. I restarted the phone 4-5 times, no luck as it faded after the PIN entered. But at last, I reseat the MMC on my phone and restarted, solved~! until today. What I suspected was, some application that I installed into MMC failed to load, similar to our Windows couldnt load the startup items... : ) So, you may try to reseat the MMC or without the MMC and see how it goes...
Maybe your backplate is loose and thats causing the mmc removal warning.
