I have TOM TOM 5 loaded on my 6680 and I'm trying to pair it with my non Tom Tom GPS device. When I search for devices I can see the gps device in the list and when I select it nothin happens.
Is there somethin I need to do with the GPS device??
Richie
richieno9 wrote:I have TOM TOM 5 loaded on my 6680 and I'm trying to pair it with my non Tom Tom GPS device. When I search for devices I can see the gps device in the list and when I select it nothin happens.Is there somethin I need to do with the GPS device??
Richie
I can't actually help you with the problem, but if you goto
www.pocketgpsworld.com. You will find a section for totom mobile and probrbly the solution to your problem. Seems loads are having problems with connecting gps receiver
Richie
forget about TomTom at this stage. if you can see the gps when you search for it but cannot pair with it then either the GPS unit or your phone is faulty.
