HELP (using Push To Talk)
1 replies · 4,264 views · Started 15 July 2005
First of all, your [network] operator must support it (the Nokia PoC, Push to talk over Cellular, version). Check their web site or call their customer service number to find out. If your operator doesn't, you can stop here as Push to Talk doesn't work without the appropriate infrastructure (servers and services) on the operator's side.
Secondly, if your operator does support Nokia PoC, you need to get the operator to send you the push to talk settings (as a configuration message, or so that you can enter all the settings). If you don't get the settings from your operator, then there's nothing anybody else can do for you.
And after that you need to find somebody else using the same operator, and also a Nokia PoC capable phone and form a group with that person (or all of them, if you find more than one). If you've reached this far, but haven't found anybody else using it, then having the service for only you don't make any sense (you have nobody to talk to).
