:cry:
I can't seem to download even just the playlist.... I keep on getting network not found!
I don't think it's my gprs access because web viewer and wap works just fine.
Anyone pls help!!!
:cry:
Anyone pls help!!!
Despite of it, that's the most likely reason. You should be using the same settings as when using 7650 as modem. On some cases that's different from the WAP settings.
Other one could be that the playlist can't be found or you have a typo in the URL. You can try and contact Oplayo tech support for further help.
** Magic **
i have the same problem with you vtr, where are you from???
