can someone help me by telling me how to put apps on a 3650 through the mmc thanks
i
putting apps on 3650 via MMC
Use a card reader and copy the SIS file anywhere in the MMC.
Install FExplorer from http://www.gosymbian.com
Browse to the SIS file and open it to install.
Then u can delete the SIS file.
But there can be a problem. First u have to install FExplorer. If u dont have any third aprty file manager, then u must have other alternative to install one first. U must have an IR or Bluetooth dongle and install FExplorer first or any other way u find comfortable.
i have infared built into my laptop. how do i turn it on?
Try this
Activate IR on ur phone and place ur phone near ur laptop so tht both the IR ports are close enough for the transfer.
Right click on the SIS file on ur computer and select 'Send To'. Now select Infrared.
u may transfer via irda also using pc suite, there s comfortable file broser
finally got it to work I had to go to my system bios to turn infared on. thanks guys
Welcome.
