how to copy data from nokia 6260 to PC?
5 replies · 2,293 views · Started 16 July 2005
Hi all!
can i use bluetooth for copying files or sync?if yes how to do?
bcoz i do have ifra.
Best regards,
Thirith.
N/A wrote:You can use Bluetooth, if your PC also has Bluetooth (and you might want to also install PC Suite: http://www.nokia.com/pcsuite).
i have install PCsuite in my computer but when i try to connect my phone to pc it did not have connect through bluatooth. it have ifra and com1 com2 and usb port not have bluetooth.
how should i do?
thanks,
thirith.
Have u installed the bluetooth drivers properly? Try reinstalling.
U can also send files without PC Suite. Select the file and send it directly to the PC via bluetooth.
If u want to use Ird, make sure the ports r facing each other closely within couple of inches. Somehow, the Ird wont stay up for long if it doesnt find any connection ... u got roughtly less than a min. i tried it couple of times and got pissed off and went out to buy a cable. its much better and faster than Ird.
I would say, just go buy a bluetooth dongle, they cost around Rs. 500 to 1000, and make syncing with the pc easier.
eg. my fone auto syncs the contatcs everytime i enter my computer room, wthout any manual intervention.
The cable is faster, but more expensive to like 3000 upwards.
