No soft keyboard on A1000?
3 replies · 2,710 views · Started 17 July 2005
Hi, I've just started using OPL on my new beloved A1000. Having read through the manual and jumped in, I've managed to set my project up but am unable to launch the on-screen keyboard - only method of alpha/num input. I click the relevant icon on the status bar, it flashes and then... nothing. My assumption is that my application window is miles above the window the keyboard is in. (have only spotted "gORDER" which only seems to work with windows created by my application. Any suggestions?
Grant
Query wrote:Hi, I've just started using OPL on my new beloved A1000. Having read through the manual and jumped in, I've managed to set my project up but am unable to launch the on-screen keyboard - only method of alpha/num input. I click the relevant icon on the status bar, it flashes and then... nothing. My assumption is that my application window is miles above the window the keyboard is in. (have only spotted "gORDER" which only seems to work with windows created by my application. Any suggestions?
Grant
We need to put on the screen a "text filed", or how you call it; I'm still trying to understand how (if possible) to put any control (labels, buttons, text boxes...) on the screen, but I can't find anything. Looks like the only way to allow virtual keyboard input is using standard dInput dialog (quite tricky to be used...).
Hi there i need some help please:
I am trying to use soft or virtual keyboard on A925 with
dInput but application closed with error: cone4 or something like that
Please tell me how can i use virtual keyboard to fill dINPUT with text.
