how to execute c++ application
2 replies · 1,654 views · Started 18 July 2005
hey ppl...i m a newbie in symbian application dev...need help regardin execution of c++ app in symbain os....which emulator shud i use???...how do i execute a code??....is it possible to emulate edge app????
reply asap..
netsonix
You should use the emulator in the SDK version for the IDE (Integrated Development Environment) that you have; CodeWarrior, MS Visual C++/Studio or Borland BuilderX.
You should also make sure you pick the correct SDK version for the device(s) you are going to target (Series 60 1st Edition, Series 60 2nd Edition versions, Series 80, UIQ). Which phones did you have in mind, exactly?
well iam also using borland c++ mobile edition and to executee it on emulator u can install nokia 60 series emulator on it and can run ur application by making sis file for target machine.And do tell me how to make application on c++ do tell me on
[email][email protected][/email]
netsonix wrote:hey ppl...i m a newbie in symbian application dev...need help regardin execution of c++ app in symbain os....which emulator shud i use???...how do i execute a code??....is it possible to emulate edge app????
reply asap..
netsonix
