Nokia 9500 CMdaAudioOutputS Error With TomTom Mobile5
14 replies · 4,191 views · Started 18 July 2005
Finally received my TTM5 and when I start TomTom from the desk, I get the following error:
Program closed
Program: TomTom
Reason code: CMdaAudioOutputS
Reason Number: 6
Does anyone know what this error is? And how I go about fixing this?
I've asked TomTom CS and waiting for a reply, could be awhile, :frown:
Carl,
CJackel492 wrote:Finally received my TTM5 and when I start TomTom from the desk, I get the following error:
Program closed
Program: TomTom
Reason Number: 6
What happens if you restart the 9500?
Steve
CJackel492 wrote:Same thing, Did a battery out reset,
Carl,
Hmmm.... the error message suggests a problem with the audio side of things. Have you anything else installed which might be trying to lock/use the audio circuits?
I'll forward your problem to TT myself and see if I can get one of the programmers to comment.
Steve
slitchfield wrote:Hmmm.... the error message suggests a problem with the audio side of things. Have you anything else installed which might be trying to lock/use the audio circuits?
Steve
All I can find in my installed apps relating to audio is:
Advanced audio support V2.0 System - Nokia Content
MediaServer OPX (C) Symbian V0.40 System - Unsigned (Installed with Smuggers)
Streaming Audio Backport V1.0 Application - Unsigned (Installed along with Astronix)
I don't have any apps that auto start that I'm aware of,
I have contacted TomTom but knowing their CS, I don't expect a reply before 48 hours, :frown:
But thanks, Hope you can get a reply,
Carl,
CJackel492 wrote:All I can find in my installed apps relating to audio is:
It's worth trying removing Astronix. MediaServer OPX is OK, as that's on my unit as well.
Steve
slitchfield wrote:It's worth trying removing Astronix. MediaServer OPX is OK, as that's on my unit as well.
Steve
I've tried removing the apps, Rebooted, but it's still the same,
All I've got on at the moe is:
15 V1.0 Application
Adobe Reader V1.1 Application
Advanced Audio Support V2.0 System
AppFrame OPX v0.95 System
Bounce V2.0 Application
Common Catalog V1.22 System
Common Connectors V2.22 System
Common Security V1.22 System
Converter V3.2 Application
MediaServer OPX (C) Symbian... V0.40 System
OPL Developer Tools V1.51 Application
OPL Runtime[Thumb] V1.53 Application
Pro Tour Golf V1.4 Application
sBasic V0.9 Application
SendAs OPX V0.95 System
System OPX V0.95 System
XviD Codec V1.10 System
Zip manager V3.10 Application
Carl,
Did TomTom get back to you? They didn't to me...
Insanely great software and appalling comms to their customers :frown:
Steve
CJackel492 wrote:No reply yet,
96 hours and nothing, :frown:
This is not good,
Carl,
You have private messages.
Steve
Right, I decided that I would reformat the phone,
Reformating the phone, TomTom Mobile 5 now works,
Could not backup all my settings and have been reputting them back in, slowly,
I am now reinstalling all the software I had on my phone, one at a time, then checking that TomTom still works,
I will post here when I find out what program conflicks with TTM5,
I have noticed a bug with TTM5 for the 9500, when using custom voices and POI warnings, the bit rates seam to change, sometimes the voices are like a chipmonk and other times, like Barry White,
Carl,
P.S. Thanks Slitchfield for the address,
CJackel492 wrote:I will post here when I find out what program conflicks with TTM5,
Thanks, very curious about this!
Steve
Is it a specific version of TTM5 for s80 phones or does the new TTM5 work in all nokias??
matt1 wrote:Is it a specific version of TTM5 for s80 phones or does the new TTM5 work in all nokias??
I haven't got the retail version (I had a late release candidate emailed to me), but I believe you say which version you want when ordering and the right sort of MMC/binaries get included in the right box, etc.
Steve Litchfield
slitchfield wrote:I haven't got the retail version (I had a late release candidate emailed to me), but I believe you say which version you want when ordering and the right sort of MMC/binaries get included in the right box, etc.
Steve Litchfield
Yes, when you order, you choose which phone you want to use it on,
Carl,
