Old nokia ringtones?
8 replies · 7,377 views · Started 08 November 2002
How can i add old nokia ringtones in the new 7650's composer?
Is there a way to convert them into this type?
use the regular key press types, they do work right?
__________________________________________________________
PS: you should condider MIDI's and Wav's, they are much better sound quality.
I'll try that.
And 1 more thing. I can send games and programs ,ringtones, wavs etc. via IrDA through my PC using PC Suite right?
Or i must use Bluetooth?
E.g. to send Doom can it be transfered via IrDA port?
[quote="ARMac"]How can i add old nokia ringtones in the new 7650's composer?
Is there a way to convert them into this type?[/quote]
compose old ringtones from 3310, or send downloaded ones from 3310 and send to your 7650. i tried that, it worked... but who needs those old ringtones??? midi is the way!!!
