After charging my telephone cant find the operatore!!Then after 3 hours everything is allright!What is the problem :frown: ?
Serious problem with Nokia 6680!
Hard to say. Did you ask your operator if they had a network/service break or something at the time in the area where you were then?
Try this....
Settings ... Connections ... Network / Automatic .. change to manual.... that will
search for operator...
cya!
i have nokia 6680 and i see at the screan Offline how i can fix this problem and
when i use the SIM Card it show me this Message "Sim Card not Valid" please help
iMei :355661004954566
Code :0523689
FCC ID:PDNRM-36
IC:661R-RM36
Wirelessly posted (NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Unlock it from the network it's locked to.
please any way to fix this prob
I was wondering i have just bought a second hand nokia 6680 and for some reason it's coming up saying " Sim Card Not Valid " although when i take the sim card out and turn the fone back on it loads up perfectly and i can access all the fone menus etc except for it saying it's offline. Now i know that the offline is in reference to a profile setting and when i go to change the setting it then asks me to insert my sim card. When i do this and turn it back on it once again comes up with the " Sim Card Not Valid "
So if someone can help me as to what i should do with this or should i just continue to use it as a paperweight?
Change the SIM card for a newer one. how old are Your SIM?
