Remove nokia 7710 apps?
2 replies · 3,393 views · Started 18 July 2005
martinbodda wrote:How do i remove nokia 7710 apps from the phone?? 😮
Thx in advance//
Martin
go into control panel and then app.manager click on the application you want to remove then click remove..........
I also advise you to find the setup file of the program you want to remove (by using file manager) and delete it...
