Now that I have my 9500, my wife has tried and then we saw the 9300 we wants to get one for her - at the moment she is using a 6600 (Series 60).
I am not clear if such a migration is possible without some problems.
1. PC Suite.
PC Suite 6.6.16 is quite good however it is not compatible with the 6600 to such an extent that the PC Suite for Nokia 6600 does not seem to work properly with this installed.
Windows XP Service Pack 2 using MS Bluetooth was being used.
The only thing I can do here sofar is use another computer to take a backup of the 6600 contacts etc.
I considered if a files can be transferred via the MMC - however there are 2 problems with that: the first one is that there is a 'backup to memory card' on Series 60 like there is on Series 80 - and secondary the files are not compatible.
The obvious files to copy across if they were would be:
logdbu
contacts.cdb
calendar
The message store.
Yet issue here is that the Nokia 6600 wipes the 'general log' if we were to
swap SIM cards.
2. Email.
This is not a problem as such because I just redo the settings and download the messages again.
3. SMS/MMS etc.
Much more problematic - I cannot think of a way migrate SMS and MMS messages between a 6600 and 9300.
4. Calendar/To do entries.
This should be possible if a can get PC Suite Working expect I need to use a machine with full MS Office version of Outlook of course.
Again see point 1.
5. Contacts.
Is there any way to have the 9300 and 9500 read the Series 60 'contacts.cdb' or another machine so that the pictures and extra contact lines (that Outlook cannot handle) can be transferred.
6. Games.
The Communicator version of Bounce has always been the best.
Can I still use the Nokia 9210 Bounce Level Enpansion packs to add levels 12-21 to an already installed 9300/9500 version of Bounce.
Related to this where is the 'Bounce Back' game (the sequal that I have heard of).
Secondary: Java applet games.
I have noticed that some simple JAVA applet games work in the 9500 so what about JAVA games for Series 60 - has anybody tried to see.
Obviously I am talking about playing them on the PDA side.
This might be useful especially as Rayman 9210 does not work on the 9300/9500 but perhaps the JAVA version for the 6600 can be downloaded and might.
I really hope that somebody who works for Nokia reads this.
The points made here are simple - people still use the 6600 (so perhaps allow the earlier Series 60 phones to use the later software - 9210 is not a problem - I was able to migrate because there was a proper program for that) and being able to migrate from Series 60 to Series 80 may well result in more Nokia 9300s being sold (which no bad thing).
