3G elimination
3 replies · 1,572 views · Started 19 July 2005
You can't "remove" it, but on most variants (unless your provider has requested it to be disabled for some strange reason or another), you can simply change it in the "Settings" app (change Network settings > Network mode from "Dual mode" to "GSM"😉.
N/A wrote:You can't "remove" it, but on most variants (unless your provider has requested it to be disabled for some strange reason or another), you can simply change it in the "Settings" app (change Network settings > Network mode from "Dual mode" to "GSM"😉.
Thanks,but I cant do it in my old firmvare. I need application(which I had once,but disappeared somehow).
Hi!..
This app attached can disable the 3G ...
It�s a very complete test field app ... with many variables...
There you can choose: Dual Mode, GSM or 3G ...
Install the app... start and browse the options using the arrows ...
you will find on one of the lastest section that option... and put modify and the number of the option you want... then you will be asked for restart... yes and done...
hope this help you... i use it in my 6630 .. now i have a 6680 and i don�t use that app because it came with that option build in settings...
cya!
Attachments: operator.zip (69 KB)
