Here's an odd one. Got a newish 6630, factory reset, so effectively virgin.
I go to Nokia's support site (http://www.nokia.co.uk/nokia/0,6771,64931,00.html
) and see various software. I download one of the apps and copy across to the 6630. I try opening the SIS file and I get
'Go online and check application validity'.
Never seen this before, on any Symbian platform. If I press No, the installation just stops, if I say Yes, I get the immediate error message 'Certificate revoked for this application'.
Maybe the answer is that the apps were put up by Nokia last December and have simply time-expired? If that's the case, you'd have thought Nokia would have noticed by now and fixed the cutoff dates or removed the items?
Wierd, wierd....
Steve Litchfield
