hi guys ,
My sendo x is very slow , all the applications opening very slowly ,i feel 6600 is working better than sendo x.Is there any way to make it work better
hi guys ,
what firmware are you using and what applications specifically do you think are slow? depending on how much "stuff" you have installed, sometimes a good reformat and re-install of only the applications you need most does the trick 😊
fwiw - i had my 6600 bogged down with so many things that i noticed it was slow as well. reformatted it and all was back to "normal".
Mordred 660 wrote:what firmware are you using and what applications specifically do you think are slow? depending on how much "stuff" you have installed, sometimes a good reformat and re-install of only the applications you need most does the trick 😊fwiw - i had my 6600 bogged down with so many things that i noticed it was slow as well. reformatted it and all was back to "normal".
I use the latest firmware , i install all the applications in the card , i dont use the internal memory .When i open a message it takes much of time to open and the contacts too
loading them on the card may be the problem - try loading apps onto the phone itself as you are not really gaining anything by loading them on the card. it will increase your speed quite a bit.
Mordred 660 wrote:loading them on the card may be the problem - try loading apps onto the phone itself as you are not really gaining anything by loading them on the card. it will increase your speed quite a bit.
fine i will load the appilcations in the phone , will tht improve the speed of opening contacts and messages
not really, no. after a fresh fromat/flash/format i would install what you use from scratch - all onto the phone itself. mine is just fine for my needs - but i do see what you mean about the messages at times.
