Found a 256Mb DV RS-MMC
4 replies · 2,357 views · Started 19 July 2005
It's been a while I wanted to upgrade my 32Mb RS-MMC DV. I'm in the US and it is already difficult to find a RS-MMC but a DV it's almost impossible. I found a company TopRam in Fremont CA and they're selling many different type of memories.
I found a 256Mb on Ebay and the posting was linking to their website www.topram.com
I received the memory yesterday, tested it and everything is working great on my 3230.
If you're like me (living in the US) and you want to upgrade your RS MMC DV don't hesitate to give them a try.
Exactly, u dont need the dual voltage rs mmc. Just buy the normal one rs mmc. Much cheaper, many more options of brands. I'd suggest transcend.
MatejW wrote:Hmm doesnt n3230 use non DV cards? Yes i know that DV cards works 2, but not on a DV...
hmmm
I've just had a look at the instructions i downloaded from the nokia website some time ago and it says the following
Use only compatible
MultiMediaCard (MMC) with this
device. The compatible MMC for
your phone is Reduced Size Dual
Voltage MultiMediaCard.
