i just got my nokia 6680....n the dealer formatted the card that came with it...now there are bunch of software that are pre feeded by nokia in the mem card...now they are formatted...is there a way i can get those...nokia.com doesnt have it....i checked the cd that came with it and it doesnt have those either....i dont know if anyone else has the set so i could copy the softwares from them...n i asked the dealer he said he cant really open other boxes and told me to wait...its been few weeks now....plz help me out
thnx
I know you said you checked Nokia but...
http://www.nokia.co.uk/nokia/0,8764,71259,00.html
I'm guessing you have already seen this? And want the rest?
Everything that came on my MMC can be found here -
thnx alot, yep i got it...i have another problem n i know many of u have same problems..... now the videos n images show up in gallery no matter if u put it in folders...now that is a pain in the butt...as so many ppl play wid my phone it gets annoyin if they get in to private files...which they do very often...i was looking for a program that would solve this problem....
i tried smart crypto...now putting pass on each file is pain too...
is there a software that would allow me to put password on a selected folder....n in order to access the folder or its contents u would be prompted to enter a password...but i looked every where n couldnt find such software...another solution was to use sms guard...it does what i want...takes files n puts password to as many as i want as a whole...but when i go to fe explorer the file is visible n there is another copy of it...it is not accessable but there are so many files created when i use that....
another solution was... i saw someones 6630 n they had this software...i dunt know the name, it allowed them to put password on the whole messaging icon...so when ever u tryed to even click the messaging icon it would prompt u wid a password....so there is no way u can access the whole messaing side...that means no inbox...no new sms....and cant even write sms without the password....
if anyone knows the above software...that would solve my problem
thnx alot for helpin me before
