Where are the Messages, Calendar & Contacts?
0 replies · 1,447 views · Started 19 July 2005
Ok, I think I'm gona try to format the phone to try and get TomTom working,
I know PC Suite should make a backup of the phone and then be able to restore it afterwards, but...
I would also like to save the files manually? Is it possible? Where are they stored?
I'm hoping if I restore it manually then if there is a problem with the something on the phone then it won't be copied back on to the phone as if I did a restore?
Also I suppose, e-mail settings?
Carl,
