I did a little search, is this what 5.22 fixes?
Cover UI:
* Support for transparent Operator logos
* Infrared and Bluetooth activation to Go-To Menu in Cover
* Active Sim Access Profile connection on cover UI indication
* NITZ update notification improvement
Telephony:
* Emergency calls supports all voice codecs
* Single numbering scheme for fax added
* USSD editor added to communcator side (under control panel)
* Closed User Group support added
* Local DTMF tones playback added
* Speed dial entry improvement
* Unanswered USSD request improvement
* Contact search improvement in CUI
* CBS application icon location correction
* Calling name correction
Messaging:
* Instant Messaging PDP context will be released after 5 min
Multimedia messaging:
* Usability improvements to MMS Account settings
* Delete option added for non-media objects in MMS editor
* Capability to reply to MMS with SMS added
* Support for 300 kB MMS messages if requested by operator
* MMS viewer (closing phase) correction
eMail:
* Move to folder -dialog remembers the last used folder
* Forward functionality added to sent folder
* Sending email always goes from default account
* Support for IBM addresses added to email
* Retrieved emails converted to the device local time
* "Mark read/unread" functionality added into messaging centre menu
* User selectable character set added to email editor
* Email notification is shown according to setting
* Functionality of "Delete e-mails locally..." with POP/IMAP.
* Improvement of installed push solutions when creating new message
* Handling of Word document (containing pictures) attachements improved
* BlackBerry meeting request support for Notes email addresses in attendees field
* BlackBerry email account setting handling improved during simultaneous server connection
Calendar / PIM:
* Meeting Request support for email / PIM solutions added
* Location field in calendar event supports 128 characters
* RDATE Support (for WEA)
* User not prompted for HTTP Auth. id/pw on bootstrap & connect fails
* Correction of dst start/end time
* Animation for Sending New/Update/Cancel Meeting Requests
* Correction for maximum length of address control in calendar meeting request
* Calendar speed improvement
* WEA synchronisation improvement concerning cities without daylight settings
* Calendar Sync - Maximum length entry in Description field set to 128
* Sanity check added to calendar sync to filter out invalid calendar entries
Office tools:
* Improvements to fonts when showing slideshow with data projector
* Transparent bitmaps are supported in presentations
* Showing bullets improved in presentations application
* Word and Sheet: Intermediate saving not to be done when cover is closed
Wireless LAN (9500):
* Cisco Aironet IE will be only sent when detected that AP supports it
* Improved WEP key setting
* UI text changes in EAP-PEAP eap sheet
* Improvements to Identity dialog pop up window
* EAP-GTC identity dialog improvements
* PEAP and EAP-TLS authentications interoperability improved against Cisco ACS server
* EAP-TLS support to IBM networks added
* Interoperability improvements for Beeline WLAN operator
* Improved the WLAN co-existence with mp3 player
Device Management:
* Generic usability improved
* IP Passthrough option added to OMA Device Management Access Point configuration
* User is alerted when application waits installation
* User is alerted when incoming note is received
* HTTP authentication added to Device Management
* OMA Client Provisioning support for HTTP authentication added
* OMA Data Sync Client OMA CP Provisioning for HTTP Authentication added
* Improvements to device management accesspoint and VPN accesspoint co-operation
* UI Improvements when creating new configuration
* Offer APN product profile information for BlackBerry client
* GPRS shall be initiated when *99# is added to FDN list
* Correction of sync profiles created with device UI with OMA DM
* Contacts content type can be configured into syncml settings with Nokia configuration tool
Browser:
* Accept header HTTP transport framework filter for the browser
* Password field supports Non - Alphanumeric characters
* Streaming improvement
* Flash6 plugin support
Media:
* Video Playback functionality improved
WLAN:
* EAPOL packet handling updated
Others:
* Bluetooth SIM Access Profile support added (9500)
* "Note List" shortcut added to Desk main view�s command buttons
* Shows all Quick notes in terminal with one view
* Capability to re-run the automatic IAP configuration
* Can be done via control panel in case of deleting IAP�s eg. Accidentially
* Datamover usability improvement: asks explicitly the current city from user
* Improvements to operator wallpaper and camera co-operation usage (9500)
* Default Communicator display brightness settings lowered
* Improvements to handling corrupted memory cards (notification improved)
* Improved colour schemes in communicator side
* Interoperability improvements to Bluetooth carkits and headset audio routing
* Playback performance improvements to RealPlayer
* RealPlayer support SDP files
* Printing performance improved
* Music Player: Pause, Duration, FWD and RWD support for AAC files
* Support for MD-1 music stand added
* Usability improvements after restoring a backup (using PC Suite) and MMC backup
* User is asked to reboot the terminal
* Improvement of Home Zone functionality with new USIM cards
* Progress bar indicator on PDA during battery boot
* Improvement of Autolock functionality after PC Suite backup
* TSD procedure improvement
* Backup restore related error situation corrected to CoverUI.
* User Agent string updated to indicate correct sw version.
