Programs to store Messages in PC
6 replies · 2,297 views · Started 20 July 2005
what are the best programs to store the messages from a 6630 to the PC and view them in the PC?
Barros wrote:what are the best programs to store the messages from a 6630 to the PC and view them in the PC?
Hey, you can use the new Nokia PC suite and use the messages option to open all the messages in your folder. Then just open the messages one by one or you can copy them all together and then paste it to one of your folders in your PC. After that you can open the message from your PC if you have PC suite installed.
mfzaman wrote:Hey, you can use the new Nokia PC suite and use the messages option to open all the messages in your folder. Then just open the messages one by one or you can copy them all together and then paste it to one of your folders in your PC. After that you can open the message from your PC if you have PC suite installed.
can you explain this better? where do you have the messages option? i have installed the 6.6 and seems to be equal to the 6.5!
Barros wrote:can you explain this better? where do you have the messages option? i have installed the 6.6 and seems to be equal to the 6.5!
Open "file manager" (it is the windows explorer extension), choose your view such that you can see folders on the left hand side. When you have your phone connected, you can see "messages" folder under your phone. When you click on it, PC Suite 6.6 will install a SIS package to your phone and then you have upgraded your phone to support syncronising messages from your phone to PC.
