psln00 file...
4 replies · 1,952 views · Started 20 July 2005
for everyone in this world i need u'r help, if one of u have this file "psln00" please sent to my email.... [email][email protected][/email] :frown:
i realy...realy.... need this file.....
thanks before.....
:icon2:
Can you give some more info? Like what's the extension type, how did you lose this...Maybe a hardreset will do the trick? I tried looking for it on the C/D and Z drive, but couldn't find anything.
i went tray ngage posible to use theme like 6600, and in oher forum ahave this posible,
1) take psln file in z:system/app/psln(folder)
2) take psln.dat in z: system/data/psln.dat
3) take psln00 in z: system/libs/psln00.dll
4) series60skins suport in z:system/instal/
5) the skin folder in z:system/skins
i have this from other forum( actuali in arab forum and spanyol forum i think ) cost i dont understan the language cost they not use english of all,
and i hear sendo is symbian os6 same as n gage, but its posible to use theme, and i think this file should be have in this phone, cost they say they have the file, but it has along time discus and it posible, this the link http://www.mobile-freaks.net/forum/
so if u found this file please sent to my email or att in this forum
thanks for your reply..... :redface: :icon14:
That is not possible on Sendo. Sendo has its own theming format. When you look around you find some nice themes.
Cheers, murphy
Indeed, and also the 6600 has series60 v2. The Sendo X has series60 v1. So a simlpe copy/paste off a .dll won't do the trick. But have a look at the sendosmartphones website. Make sure you choose the right fw you're running on your X. Good luck!
