PLease Help!!!
i had on my previous 7610 mmc all my videos that was in rm format. i have stored it to my pc and now tranfer it to my new dv rs mmc card for 6680. The problem is that the nokia 6680 cannot play the video.
Is there any programme that i can convert them again in rm format so that the 6680 can play them.
and please i dont want to use smartmovie or anything like that. just a simple real media format for the phone.
thanks in advance!
Real Player comes with the phone so you shouldnt have a problem playing them
unfortunally th real media that plays to the 7610 is are not playing on 6680.
i will make my self more clear to understand, is not 3gp or 3gpp or avi. its .rm extension and the nokia 6680 cannot play them
im just asking if anybody knows a good converter tha is comppatible with real media video files to 6680
@sniper I have the same problem,.... if u find one pls... post the link... tia
sniperak wrote:PLease Help!!!i had on my previous 7610 mmc all my videos that was in rm format. i have stored it to my pc and now tranfer it to my new dv rs mmc card for 6680. The problem is that the nokia 6680 cannot play the video.
thanks in advance!
I use ImTOO Mpeg Encoder to change files from RM to 3GPP files. Unfortunately a lot of quality loss though. :frown:
i know tazanni , thats why i would like to convert them to real media format. 3gp is not very clear as it should be. .rm is the best
tazanni wrote:I use ImTOO Mpeg Encoder to change files from RM to 3GPP files. Unfortunately a lot of quality loss though. :frown:
What settings do you use with converter? It gives me an error when i try to convert from rm to 3gp. i can convert from avi or mpeg though.
www.pocketvideomaker.com will make .rm files for you.
thanks!! i ll give it a go!! 😉
I Download the full version of the software and it works extremelly well with perfect quility. thanks willbrady. :icon14:
