Imagine you could sit at a movie, class or a meeting and still keep answer phone calls while maintaining silence. "Talking without Talking" allows you to do just that!
Silent Communication is currently releasing the "Talking Without Talking" (TWT) solution for usability feedback and comments.
TWT supplied with a default ready-to-use response set, Activation and deactivation of the service is done using a most commonly used action � switching the device to the Silent Profile (vibrate). As expected, not all responses may be predicted and prerecorded, and sometimes it is required to compose an on-the fly response. For those situations users may type the full text of their response, the same way they type SMS messages, and TWT will convert the response to speech using Text to Speech technology.
Moreover, sometimes calls just can't be answered, however, the caller is too important for you to reject, or does not deserve such rudeness.
Now you can use Smart Reject, with just one click the phone can answer the call, play a personal response that promises your attention later, and terminate the call.
TWT application is compatible with all Series 60 Symbian 7.0 and above devices, currently tested with the following phones:
6680
6630
6600
You are welcome to download a 90 days trial of the application from the following link:
http://www.silentcom.com/Downloads/TWTSmartPlus.zip
:shakehand
We hope you�ll enjoy the application and we�re looking forward to your comments.
[[email protected]][email protected][/EMAIL]
