A1000 Agps
2 replies · 3,570 views · Started 21 July 2005
Hello,
Was hoping someone could help me out with a couple of issues on my A1000.
How do you use the AGPS? I have installed nhGPS and after 10 minutes it is still searching for my location. Independently of what country I am in. Is there something special to do? The little icon at the bottom is blinking white and red. Also do you need to be connected to the GPRS at the same time?
Also - often I can not register my phone on any network I select when it works well when I transfer the SIM to my P900. So I know it is not an issue with my plan. Anyone had the same issue?
Thanks for the help !
J.
I've got the same problem... 🙄
What happens, if You lose the position for a short periode.
How long does it take until You've got the position again?
Do You have to wait for another 10 mins? :thumpdown
Kind regards
Steve
