2 Nokia 6680 memory card problems
3 replies · 11,591 views · Started 22 July 2005
Hi!
I got two memory cards for my Nokia 6680! The on that cam with the phone (64MB) and I have also bought a Kingston 256MB MMCmobile flash card.. I have a problem with both of them..
The problem with the 64MB card is just weird. The name of the card has turned into a lot of strange signs (like @#$: and I can't format it or anything from my phone!
The problem with the Kingston card is that my phone will not recognize it! My phone says no card inserted, when it is! As I already told you it's a MMCmobile card, those should work just as well as a RS MMC? It's also a divided voltage card.. (1,8V/3,3V)
Anyone have answers to my problems?
Davidfaen wrote:Hi!
how do you get a full size mmc in your phone. if you try this on the 6630 you cant close the door so the card is not recognised.
DV means Dual voltage not Divided voltage....
cyberkid999 wrote:how do you get a full size mmc in your phone. if you try this on the 6630 you cant close the door so the card is not recognised.
I know, I meant dual voltage, my fault.. MMCmobile is not a full size MMC card, it's exactly the same size as a RS MMC.. And I know alot of guys with a MMCmobile card in their Nokia 6680 that's working. So I wonder what's wrong with mine.. When the card says 1,8V/3,3V does it mean it can be used by phones that require 1,8V or 3,3V? The 6680 needs 1,8V (I think) but I don't know much about these things..
Davidfaen wrote:When the card says 1,8V/3,3V does it mean it can be used by phones that require 1,8V or 3,3V? The 6680 needs 1,8V (I think) but I don't know much about these things..
yes you are correct. A DV card should work in either system ie a DV RS-MMC should work in a 6630/6680 and with its adapter it would also work in a 6600 thats takes full size 3V cards.
