If not are there other programs which do the same purpose that will?
Nish
Nish
nish wrote:If not are there other programs which do the same purpose that will?Thanks
Nish
Fidelko wrote:as i know its working on 6680
haven't you considered getting netmonitor for it instead?
Being new to Symbian and stuff, I'm wondering what advantages are there to tracing the cell that you are in? Is it just something nifty to do or is there practical uses?
Peter
CellTrack (and miniGPS and GPL-2) all work on the 6680, but they seem to count backwards on their signal strength percentages. The better the signal, the lower the percentage, where as a a bad signal will give a percetage of over 105%!
The battery meter does seem to work properly on CellTrack, but is screwed on GPL-2.
(all three work flawlessly on my Sendo X)
So which one is actually better for the 6680? Net monitor or CellTrack?
I thought they both done the same job :redface:
