Does the Nokia 7650 support operator logos? I tried sending one but it was saved under a directory c:\apps\phone\op_logo but it won't display
Operator logos?
you need a code of your provider... this is the name of .bmp ejmp.
Vodafone Spain: 214_1_0.bmp
Regards...
I didnt quite get that. What exactly do you mean? At the moment I have a file called 234_10_0.mbm where do I get the codes?
[quote="zeus68"]I didnt quite get that. What exactly do you mean? At the moment I have a file called 234_10_0.mbm where do I get the codes?[/quote]
What he is saying is... that you should get a particular file from your operator... which looks sommin like xxx_xxx_xxx.bmp...
You have a file called 234_10_0.bmp... the three sets of numbers ARE the CODES...
So it looks like you have the right file 😃 ! So I don't know why it don't work... :cry:
Im not exactly an expert.. since I don't have any of these fones.. YET!!
but... is there an option in any of the settings menu's?
Dodgybob
a regular... "but I dont even have a phone" :cry:
www.dodgybob.co.uk
wich is your operator?? ejem: Vodafone_spain
[quote="zeus68"]Does the Nokia 7650 support operator logos? I tried sending one but it was saved under a directory c:\apps\phone\op_logo but it won't display[/quote]
The path should look like this
The MCC MNC, you can find it at
Z:\System\bootdata\operinfo.txt (inside your NOKIA 7650)
