A couple of weeks ago, the Turn Screen (#) and Scroll (0) functions stopped working. Full Screen (*) still works. I've since upgraded the Sendo firmware to 1.198.8.2 and MobiReader to 4.9, but no change. Have I disabled these functions without knowing? How?
BTW is there a search function? I can't find it. Is it absent from the S60/Sendo version?
In order to have Turn Screen (#) and Scroll (0) functions you have to buy the Mobipocket reader. They are not part of the standard free version.
You will find on the Mobipocket site a table which compares the functionality of the standard version to the pro version
HTH
scrumbeans wrote:In order to have Turn Screen (#) and Scroll (0) functions you have to buy the Mobipocket reader. They are not part of the standard free version.You will find on the Mobipocket site a table which compares the functionality of the standard version to the pro version
HTH
Thanks. That's exactly it, doh, should've realised that!
http://www.mobipocket.com/en/Support/KBase_article.asp?ArticleID=27
http://www.mobipocket.com/en/DownloadSoft/CompareReader.asp
