Great little mobile!!
However, I can't seem to locate some things.
First, it does have a speaker phone, correct? I mean, where you can hear
the person talking loud, without having the unit up to your ear.
Where is the function for that?
Also, there is a music video, and the sound is very loud, so again, just like the
speaker phone, you don't need to hold it up to your ear.
Is there a volume adjustment? If so, where in the heck is it located?
Unfortunately, I use Windows98SE, and for the PC Suite, you need Windows XP.
Is there any other way to use a cable and up/download from my pc to the phone?
Any feedback or input will be greatly appreciated.
Thanks!!
did your phone not come with a manual?
Yeah, it did, but not in English and I don't ready the language it came in. 🙄
So, download a version in English (or whatever language you prefer) from http://www.nokia.com/phones/3230
(The only way to use the DKU-2 USB cable with the phone is with PC Suite 6.x on Windows 2000 or Windows XP.)
3230 does have speaker phone, and I remembered I don't need to do anything to "activate" it. when calls come in "Lousp" is shown on the right selection key and u just press on it!
My came with a manual, and it's English at the front of the manual, but doesn't come with the PC suite CD, have to download and doesn't come with the cable.
Volume control is at the left side of the phone.
dirk wrote:Great little mobile!!
Where is the function for that?Also, there is a music video, and the sound is very loud, so again, just like the
Thanks!!
Thank you both.
I've downloaded the English manual.
And yes, I see the loudspeaker and left hand button now.
Thanks again!! 😊
