Comminicator Died
6 replies · 2,804 views · Started 06 January 2002
Hi guys,
I have a new problem with my Communicator, 2weeks old. It has died on me for the second time. Today it happened in a forest and I had no contact with the outside world. The phone switched of, and I could not resart it even after removing the battery. When I got home, I just put in the charger, and took it out after the beep. All was well again. By the way, the battery was fully charged.
Please try and assist. I have firmware version 3,62..
Regards
lupo
Don't worry or better get used to it User posted image
It seems that this problem is still not solved yet with firmware 3.62. Hopefully 4.13 will have some improvements. For the time being you'd better take your charger with you...
I had the same problem a few times with 3.54, but none so far with 3.62. Let's wait and see... User posted image
Thats odd. I had that problem with 3.18, and at first i fixed it with the charger... but i noticed that if i took the battery out for 1min or so then put it back all was well!
Now on 3.54 and have never had the problem since!
[quote]
On 2002-01-06 1846, lupo wrote
Hi guys,
Regards
lupo
I also have that problem with 3.62 but can you update the firmware already to 4.13 or is it not available?
