Howdy !!!
I�m new to this forum but I was wondering if someone here could give me some technical advice.
I bought Nokia�s 6630 samrtphone a few months ago and I can�t say that I�ve had any problems with it so far. But since I�m new to the smartphone technologies I have yet to figure out how to use Microsoft ActiveSync with my phone. I installed ActiveSync 4 on my computer and Nokia�s PC Suite 6.3. But no matter how I try, ActiveSync dosen�t seem able to locate my phone when it is plugged in one of my usb ports.
Is there anyone here who might know what the problem might be ???
NightCrow
NightCrow wrote:Howdy !!!I�m new to this forum but I was wondering if someone here could give me some technical advice.
NightCrow
Your 6630 does NOT work with Active Sync. If you want to syncronise your data (contatcs, calendar, notes) with Outlook, you have to do it with Nokia PC Suite. I don�t recall if PC Suite 6.3 version supports 6630, I suggest that you upgrade your PC Suite t0 6.6 (in www.nokia.com/pcsuite) and then use the "syncronise" function in PC Suite to syncronise your phone and Outlook
Is yours through 3, if so does it stop u putting games and applications on it throu ur computer (bluetooth)
thnx abz
