Hi.
I have just got a copy of ETI Camcorder 2 for my 6680. I am waiting for them to email me the reg code, but dont know how to use it, once i have it.
Can anyone who has the software or knows how to install the reg code please tell me
Jamie
I did not realise camcorder2 was availible for the 6680, were did you get it?
Don't worry, when you run the software it's quite obvious where you enter the reg code.
It works, but with problems. If you are saving the video to MMC, 1 "second" in this program are 4 real seconds...then in PC is the video very fast....i didn't try it, I only read it...
Maybe is some new version, where is this bug fixed....
Yeah I tried the beta version for the 6630 and it had the same problem with the video playing fast, there is another version out now but I don't think the video quality is as good as the beta.
I got it from a website on the web. Ive entered the reg code now, but nothing has changed. The software is the same as the old ETI camcorder, but its been re-made for newer phones (higher frame rate, better quality etc.) I read it on another forum site. Thats what prompted me to buy it. The frame rate is the best ive seen on any phone.
Much better than Hipcam on the 6600.
Only thing is, i can only seem to get it to record from the front camera, maybe once the program is fully unlocked, it will work on the back one.
The version you have is not for your phone,thats why it is using the wrong camera.
I wrote about 6681, 6630. These phones have only 1 camera => the app uses the right one (but with bad speed)
