FILE EXPLORER for Series 80
4 replies · 13,750 views · Started 01 August 2005
Hi guys,
know any "Thorough" File explorer (Like Domi's FExplorer) for series 80 phones? specificaly for 9500?
Got a powerfile, but it only shows the usual folders, i need to see the system folders and files.
Badly need it. Thanks!
Both PowerFile and even the default File manager can show system files. You just have to enable the option first - look through the settings.
Does not allow you to see the Z: drive (rom) though. Someone posted a hack to allow you to do this from the file manager somewhere. Also most of the file transfer tools will not see any of these drives/directories, so if you want to copy files out of them, then you will need to copy them to somewhere visable.
