Nokia 6630 memory card
5 replies · 2,712 views · Started 01 August 2005
I have a nokia 6630 which says my memory card is corrupted could anyone help me with solving this problem? PLEASE!!!!!!!!!
If you have an USB memory card reader, take a look at the card from your PC with it.
If you don't, and can afford to loose data, try reformatting it with the "Memory" app in the "Tools" menu on the phone.
Have tried reformatting it and it wont let me format, but dont have a card reader but will have to invest in 1 i think.
Probably at this time you want to invest in another memory card first. If it can't be formatted then you have a hardware fault in the card....
UA
Yeah I had the exact same problem, contacting Nokia was a waste of time all I got from them was arrogance and no help, in the end I had to pay for a new memory card.
When this happened to me a long time ago I found that taking the card out while the phone was on, rebooting and putting the card back, again while the phone was on, solved the problem
