How to re-install the software fo N6680
1 replies · 4,108 views · Started 01 August 2005
hi guys i bought a new 6680 but it is network locked is there anyway i can re install the software by myself? if so how can i get the software for re installing it? please help me thro this process
in a word no, I'm guessing that you want to unlock the phone or possibly upgrade the firmware yourself? Neither of these are possible to the best of my knowledge, if you want your phone unlocked you will have to ask the network its is locked to for the code, which they will give you for a price depending on network, if your on 3 then consider it a sore one, currently there is no other way of unlocking a 6680 or 6630. If you want the firmware upgraded then you will have to take it to your local Nokia service centre.
