Like many others, I am having problems synchronising my calendar, tasks and contacts with Outlook. I have windows XP (SP2), Outlook 2000 and PC Suite 6.6 (laptop or 6.5 desktop - I have install problems with 6.6 on desktop).
At the moment, my only connection option is the USB data cable.
I have tried starting the synch from phone and 9500 with no success. I am rather confused by the different settings in PC Suite and on my 9500. I have scanned through the forum and am still unclear about the setup. I have tried adjusting these withiout success so far. I have identified the following fields that may have an imapct:
On the 9500
a) Synchronization / PC Suite profile / general
- profile name
- connection type
- Host address
- allow server alert
- accepted
b) Synchronization / PC Suite profile / user
- user name
- password
- confirm password
- HTTP authentication
c) Synchronization / PC Suite profile / contents / contacts
- local database
- remote database - what goes here if you have say "Contacts - RJP" in Outlook?
- synchronisation type
d) Synchronization / PC Suite profile / contents / calendar
- local database
- remote database
e) Device manager / PC Suite profile / profile settings / server
- server name
- server id (ghosted out on mine)
- pasword (ghosted out on mine)
- confirm password (ghosted out on mine)
- active
- accepted
e) Device manager / PC Suite profile / profile settings / connection (tab ghosted out on mine - don't know what the individual fields might be)
f) Device manager / PC Suite profile / profile settings / user
- user name
- password
- confirm password
g) Contol panel / Connections set up / cable setup / data cable mode
Nokia PC Suite
A) PC Sync / advanced / conflict resolution
B) PC Sync / advanced / Sync profile
- username
- password
c) PC Sync / Microsoft Outlook
- profile
- select folders / calendar
- select folders / tasks
- select folders / contacts
Would some kind person please publish a complete list of the settings they use for all these fields that works for them? Also please add any fields I have missed.
Thanks very much.....
