Good morning everyone
I heard we can turn the nokia 3230 into the GPS, I wonder how and what do I need to buy (hardware and software) to make my fone into a GPS. This is a good feature so I really want to know how and use it. Thank you very much you guys
If you can just type your instruction out........that will be great
You need to buy a Bluetooth GPS receiver and applicable software, such as Navicore, WayFinder, TomTom or Route66.
Hi, Im using Route 66, it comes with a memory card with all the maps on it, my set up is thus.
Nokia CR-7KW Carkit, CR-28 Cradle connected to the pop port, then I use the bluetooth to connect to the GPS unit, and all the voice commands come through the car kit which is connected to me front stereo speakers, its the cheapest form of SAT NAV I could find and although a pain that you can only charge the GPS in the car, Nokia are bringing one out that runs off a normal charger soon.
