autolock
5 replies · 4,709 views · Started 05 August 2005
This is in refrence to autolock v 0.5 which i installed on my nokia 6681. The problem is it works but i m unable to uninstall the same. i hv tried file manager to remove it also reformatted my cell by restoring to orignal factory settings but nothing seems to work. the last i tried was to install system explorer & delete the folder from z: (rom) but it just doesn't seem to delete & locks the keypad even if the application does not show in the menu.
PLEASE HELP!!!! thanking u in advance.
Try reinstalling it and then uninstalling with the [Application] Manager in the Tools menu on your phone.
Autolock in Z: is a system file and nothing to do with Autolock 0.5
You need to delete Lockwatcher.exe from the autolock folder on C:\System\Apps\Autolock (change the C: for a E: if you installed it on your memory card)
thanx 4 the reply, but seems to hv failed, please if u can tell me how to hard format the 6681, i think will do that....thanx once again
Make sure the phone battry is fully charged, or that it is connected to the charger.
Power off the phone. (You could also remove the SIM card and memory card, to be on the safe side.)
Press down the green/talk key and the '3' and the '*' keys. Keep them down (all three, simultaneously).
While the three keys are down, use your third hand 😉 to press the power switch to turn the phone on. You can release the power key, but keep on keeping the three keys down.
Wait until your phone comes fully on (it should asl for the home city/country first).
Your phone has been reformatted (with all of your data - contacts, messages, pictures, settings, apps you've installed - on the C-drive gone).
