overclock 6680
1 replies · 2,233 views · Started 05 August 2005
Your post seems to be confusing a couple of things...
"Overclocking" means running the processor (CPU) on a computer with a clock rate higher than what is was designed to do. On PC's, if the processor tolerances allow, it will get you a faster machine without paying for a faster processor. On phones it can't be done.
Overclocking has nothing to do with memory cards (MMCs).
Your 6680 does require and supports the, so called, Dual Voltage (DV) RS-MMC type (Reduced Size - Multi Media Card) memory cards. It does not support the high-speed variants (as those need hardware that the phone doesn't have).
