New tweak from SF team :: Icon package changing
0 replies · 3,287 views · Started 06 August 2005
Icon package changing, detailed guide
As you may well already know, the Nokia 6600 was the first S60 device with theme support. It has the function/feature allowing you to choose a different icon/theme set to the one which is installed as standard.
This means that you can install for example some 3rd party theme like Crystallized. Then within this theme you can change the icon set to the default set should you prefer it rather than the icons supplied with the installed theme. You may also combine any of the installed themes with any available icon set.. ...
Read more:
Icon package changing, detailed guide - full story
Sincerely yours,
Apoc
