Nok:6680 help transfering messages
8 replies · 3,278 views · Started 06 August 2005
i want to transfer my sms messages stored on phone to pc via the suite or some other prog. is this possible? which prog should i use?
thanks
every time i install ultramp3 and try run it, it disappears back to screen. so cant run program.
Try Lifeblog, it moves SMS messages - both received and transmitted, to the PC at each sync.
It's free (on the phone), but you will have to pay for the PC app after a while.
It works perfectly, also taking care of pictures.
Regards
Michael
Well .. i duno if this helps .. but the best ever program i found to transfer sms messages is " Oxygen Phone Manager " the latest is i guess 2.7 .. so u mite wana get that for symbian phone .. and d'load the demo .. read the messages in the phone .. and save as text file 😊 all messages get stored in a txt file with date and time and number in a very clean ordered way ..
Hope this helps .. 😊
